rt3891
gamecockphan
Sure, it's a long sh (762)
Domesticated Foxes? (326)
Uncharted 4 (133)
GH Recommends: Histo (118)
NCAAF: GEORGIA @ MIS (112)
Shinedown & Gods (36)
NFL: JETS @ BROWNS Thu 9/
Willy B upgrades to cost
Sure, it's a long shot
Remembering Kenny
2019 schedule out
WBB recruiting summary:
WBB: 2019 Aubrey Griffin
2019 - PG Josiah James (M
How Good Can Frank's Team
Influential Pastor steeri
Old 07-13-2018, 01:05 AM   #1
2k15
Music Lover
2k15's Avatar
CockyCash: 2016201620162000
2k15 is USC mascot material2k15 is USC mascot material2k15 is USC mascot material2k15 is USC mascot material2k15 is USC mascot material2k15 is USC mascot material2k15 is USC mascot material2k15 is USC mascot material2k15 is USC mascot material2k15 is USC mascot material2k15 is USC mascot material
Default Question About Record Player
Hey all,
So I'm definitely not as old as most people here (18), but I do have a recent interest in vintage audio, so I went out and bought myself a turntable, a few records, and a pre amp. I'm loving it so far, but I've got one problem.
Basically my turntable goes into my pre amp, which then goes into my active speakers (they have built in amps). But even with this setup, and my speakers turned up all the way on the back gain knobs, I don't get a whole lot of sound.
There's really no easy way to control the volume, and it's loudest setting on the speakers is still pretty quiet.
I was wondering if any of you older cats had any info, suggestions, or advice on how to make the output any louder. I'm trying to avoid buying a huge freaking amp to go after the pre amp, but that's currently all I can think of to fix it.
Do ya thing
2k15 is offline   Reply With Quote
Old 07-13-2018, 06:43 AM   #2
rabidcock
rabidcock's Avatar
rabidcock has hatched from the shell
Default Re: Question About Record Player
Originally Posted by 2k15 View Post
Hey all,
You are going to need amplification. It sounds as though your speaker amps are insufficient. I started out with an amp-pre amp combo, the Marantz 2385. Now I just use it as an amp (bypassed the pre amp stage) and bought a McIntosh pre amp. A pre amp balances the signal just enough to get to the next stage, the amplifier, which is where you get your power; they drive the speakers directly.
You are missing a stage (amp), therefore itty-bitty sound. Instead of purchasing a huge amp, your dealer may understand your quandry and trade you for an amp with a built-in pre amp.
There may be some electronic wizards here with a better solution.
rabidcock is offline   Reply With Quote
Old 07-13-2018, 08:13 AM   #3
GamecockInHell
GamecockInHell's Avatar
CockyCash: 1802785
GamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot materialGamecockInHell is USC mascot material
Somewhere in my storage building I have an old Marantz 50 watt receiver that has the turntable jacks. It played great for many years but I retired it when CDs came out.
GamecockInHell is offline   Reply With Quote
Old 07-13-2018, 10:11 AM   #4
rabidcock
rabidcock's Avatar
Why would you not need amplification for CD's? Also, I hope that you have your Marantz in a climate controlled storage, because humidity is a killer on electronic components over time. By the way, "turntable jacks" double as CD jacks or any other driving source you may wish to consider.
Old 07-13-2018, 11:34 AM   #5
uscgrad68
uscgrad68's Avatar
CockyCash: 648
uscgrad68 is crowing loudlyuscgrad68 is crowing loudlyuscgrad68 is crowing loudlyuscgrad68 is crowing loudlyuscgrad68 is crowing loudlyuscgrad68 is crowing loudlyuscgrad68 is crowing loudlyuscgrad68 is crowing loudlyuscgrad68 is crowing loudlyuscgrad68 is crowing loudlyuscgrad68 is crowing loudly
Hi.
Welcome to the club for LPs. I bought my first component set back in the late 60s, with a Dual 1019 turntable, Amplifier (or receiver), and speakers and upgraded when I was stationed in Japan, and since. I own thousands of LPs and love the warm sound difference, especially when compared to MP3. With the slight resurgence in the popularity of LPs it is nice to be able to upgrade older LPs, so I have purchased new 180g versions of my Beatles albums.
Yes, you need an amplifier or receiver (with AM/FM, but who listens to much of that anymore?). Amplifiers take up less space than receivers, but you can turn them sideways or tuck them behind furniture, so that they can fit your area.
I suggest you buy a "good" used amplifier or receiver (actually easier to find) on Ebay that has Phono inputs and then you do not need the preamp. Most newer amplifiers/receivers do not have the phono inputs, which then does require a preamp. Preamps need not be expensive ($20 or so) with an amplifier. I bought a preamp to go with my amplifier in order to have two turntables side-by-side, since the amplifier only had one set of phono inputs.
If you need help in judging a good amplifier on Ebay, or have any other questions, send me a PM. I also have some tips on the care of the LPs. Careful washing takes care of most of the pops and surface noise on G/VG/Exc old LPs.
Good luck, and enjoy!
uscgrad68 is offline   Reply With Quote
Old 07-13-2018, 12:18 PM   #6
ultimatetailgater
ultimatetailgater's Avatar
ultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot materialultimatetailgater is USC mascot material
Send a message via AIM to ultimatetailgater
Not sure why all the posts suggesting an amp. He already has one in each speaker if they are active/powered speakers. I use a similar setup for our football tailgates. Older ipod with dock connector to rca adapter(this is an un-amplified line out) to preamp/mixer then into each speaker(Peavy PVXp).
Not sure what the problem could be if you have the gain turned up on the preamp and speakers. What kind of preamp do you have?
ultimatetailgater is offline   Reply With Quote
Old 07-13-2018, 12:58 PM   #7
GamecockInHell
CockyCash: 1802785
It's been several years since I looked at it but it seems like I could either play the turntable or the CD player and chose the CD. I've since sold most of my 200 plus LPs to Second Hand Charles and only kept a few select collectibles. I did, however make sure I had a digital copy of each one first.
Old 07-16-2018, 11:07 AM   #8
carolina_corpsman's Avatar
CockyCash: 10500
carolina_corpsman is USC mascot materialcarolina_corpsman is USC mascot materialcarolina_corpsman is USC mascot materialcarolina_corpsman is USC mascot materialcarolina_corpsman is USC mascot materialcarolina_corpsman is USC mascot materialcarolina_corpsman is USC mascot materialcarolina_corpsman is USC mascot materialcarolina_corpsman is USC mascot materialcarolina_corpsman is USC mascot materialcarolina_corpsman is USC mascot material
If you want it to sound like its supposed to sound, bite the bullet and get a nice tube amp and some passive speakers.
Welcome to a very expensive hobby.
Sent from my VS995 using Tapatalk
carolina_corpsman is offline   Reply With Quote
Old 07-19-2018, 07:28 PM   #9
Flameout12's Avatar
Flameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot material
We used a receiver as our amps. They can be had for under $100, but seems your bluetooth speakers should have some pump.
Flameout12 is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
