Go Back   CockyTalk > Community > The Water Cooler > Carolina Eats
tcmac08
cockyguitar
DJ35
Anonymous SEC coache (1095)
Dawn Staley, Missour (944)
RELAX!!! (579)
2018 CFN Five-Year P (500)
Boiled Peanuts (453)
Boiled Peanuts (406)
Australia's New Sout (334)
Adding Satellite Rad (257)
2018 NCAA Softball S (94)
Bon Appetit's It's A (15)
Boiled Peanuts
2019 Commitment - Jahmar
Dawn Staley, Missouri AD
Bon Appetit's It's Alive
2018 SEC Tournament:**USC
2018 NCAA Softball Super
Josh Belk
Game 1 Against Coastal
Culture climb: The steady
NBA Playoffs
Old 02-01-2018, 01:34 PM   #41
Heisman Winner
thekob's Avatar
CockyCash: 100700
thekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot material
Default Re: Amazon Prime Sous Vide $129.99
Just used our sous vide over the weekend the first time. Did 4 boneless ribeyes with some thyme and rosemary sprigs, onion powder, garlic powder, salt and pepper at 129 degrees F for 2-2.5 hrs, then we dried them with paper towels, rubbed them with avocado oil (high heat) and hit them with kosher salt, then seared them to get a nice crust on cast iron skillets at around 640 to 700 degrees on a gas range.
It was phenomenal.
We also used our pressure cooker (Breville Low Slow Pro) to make some truffled mushroom risotto because we had to use up a jar of minced truffles we got from Italy awhile back. They had never been opened and had started to lose their flavor so we added the whole damn jar. It was delicious.
A benefit I didn't think about regarding sous vide steak is that a couple extra minutes in the water bath aren't going to hurt it, and we could pretty much wait until everything else was ready (minus the risotto since that'll keep absorbing liquid if it sits) to sear the steaks, which only took a couple of minutes.
I'm looking forward to trying corn via sous vide. Can't wait for summer!!!
GOD
USA
SEC
thekob is offline   Reply With Quote
Old 02-01-2018, 04:06 PM   #42
sandstorm2001
sandstorm2001's Avatar
CockyCash: 50700
sandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot materialsandstorm2001 is USC mascot material
It was phenomenal.
Outside of how consistently good the food turns out, this is probably the biggest benefit of sous vide. I normally do my steaks for an hour at 129, but that hour is pretty much always longer because I get distracted and wait too long to start my sides. From what I've read ~4 hours is the limit for when a steak starts to lose quality in a sous vide. Different meats/temps obviously impact how much extra time you have.
I'm planning on trying a flank steak this weekend. Not sure exactly how I'm going to approach but I'll report back with results. Thinking maybe I'll marinate it for 24 hours then do like a 2-4 hour cook at the usual 129. Maybe sear with the broiler? We'll see what happens.
sandstorm2001 is offline   Reply With Quote
Old 02-01-2018, 04:10 PM   #43
Master Bedroom's Avatar
CockyCash: 10500
Master Bedroom is USC mascot materialMaster Bedroom is USC mascot materialMaster Bedroom is USC mascot materialMaster Bedroom is USC mascot materialMaster Bedroom is USC mascot materialMaster Bedroom is USC mascot materialMaster Bedroom is USC mascot materialMaster Bedroom is USC mascot materialMaster Bedroom is USC mascot materialMaster Bedroom is USC mascot materialMaster Bedroom is USC mascot material
It was phenomenal.
Damn man that sounds outstanding
Master Bedroom is online now   Reply With Quote
Old 02-01-2018, 04:25 PM   #44
Heisman Winner
thekob's Avatar
CockyCash: 100700
The instructions/recipe we were working off of had us do it at 129 for 2 and a half hours. We kind of balked at that since that's a long ass time. They were around 1 lb each so they were pretty thick (maybe 2") and for the first time doing it we wanted to be sure to do it long enough (even though I don't mind a rare steak). I'm hoping next time it won't take so long.
I guess it depends how big of cast iron skillet you've got....or, maybe now you now have an excuse to get an even bigger piece of cast iron! I think tbh that our biggest skillet might be large enough to do a whole flank steak, but I feel like flank steaks aren't exactly flat so broiling might be the thing to do.
GOD
USA
SEC
Old 02-01-2018, 04:32 PM   #45
Heisman Winner
thekob's Avatar
CockyCash: 100700
It was, I highly recommend picking one up on Prime Day in July if you don't already have one.
This is the one we got:
https://www.amazon.com/Anova-Culinar...ous+vide+wifi&
It's actually the same price now as when we got it on a Daily Deal back in July. I was impressed with the unit itself and it's easy to operate, since it's just got like three buttons and has just a timer and temp control. What was irritating though was the Bluetooth had a problem staying connected when I was right next to it....like it would connect, disconnect and so on. I don't really use Bluetooth so it might've been an issue with my phone to be honest....I just wanted a timer I could look at on my phone as I did other stuff though. If not for the extra wattage (900 vs 800) I'd just recommend the less expensive model. I'm not sure how much of a difference that extra 100 watts makes though. We did think about using an electric kettle to boil water so it didn't have to heat up much...and then I realized that 129 degrees isn't all that hot, and we got like 120 degree water out of the tap.
GOD
USA
SEC
Old 02-01-2018, 04:51 PM   #46
sandstorm2001
CockyCash: 50700
You'd probably be fine at an hour even with steaks that thick. I always ask for my steaks at least an inch and half thick when I'm using the sous vide. Did some pretty hefty sirloin filets the other night actually. Maybe if you want to play it safe start your sides at the hour mark.
The boiling water method is really good if you need higher temps, like when cooking chicken. Obviously don't boil all the water, fill your bath up most of the way and get the machine running and set a pot (or kettle) to boil. Add the boiling water to your less hot water to more quickly bring up the temp of the bath. Obviously make sure you don't add so much boiling water that you way overshoot your temps.
I cook in a pretty large plastic container so this helps me out a lot so I don't have to get so much water up to temp with the machine alone.
Old 02-01-2018, 05:41 PM   #47
uscfsu23
uscfsu23's Avatar
uscfsu23 rules the CockPituscfsu23 rules the CockPituscfsu23 rules the CockPituscfsu23 rules the CockPituscfsu23 rules the CockPituscfsu23 rules the CockPituscfsu23 rules the CockPituscfsu23 rules the CockPituscfsu23 rules the CockPituscfsu23 rules the CockPituscfsu23 rules the CockPit
What do you guys cook a pork tenderloin at? I did 137 and my wife freaked at the pink. next one I did 140 and it was still good but not great.
uscfsu23 is offline   Reply With Quote
Old 02-01-2018, 06:44 PM   #48
hank scorpio
Yellow Bellied Sapsucker
hank scorpio's Avatar
CockyCash: 3300400
hank scorpio is USC mascot materialhank scorpio is USC mascot materialhank scorpio is USC mascot materialhank scorpio is USC mascot materialhank scorpio is USC mascot materialhank scorpio is USC mascot materialhank scorpio is USC mascot materialhank scorpio is USC mascot materialhank scorpio is USC mascot materialhank scorpio is USC mascot materialhank scorpio is USC mascot material
If you cooked for the appropriate amount of time at 137, the pork is pasteurized, regardless of color. No disrespect to you or your wife, but she may not understand the beauty of sous vide, in that it allows you to safely enjoy meats at lower temperatures that provide more optimal texture/flavor/juiciness. Pasteurization is a function of time, temperature and pressure.
Sous vide supplements more time in the place of more heat, allowing pasteurization to occur at lower temperatures, whereas traditional cooking relies on reaching a high enough temperature to instantly pasteurize(approx. 165 degrees). Many people associate color with doneness because in traditional cooking, they go hand in hand, but that isn't necessarily the case with sous vide. Try explaining to your wife that the juicy delicious pink pork is just as safe as the dry, greyish-white pork that is usually prepared on/in the grill/stove/oven.
It is my opinion that pink is the way to go. If you watch any cooking show or competition, pork is served pink and dinged as overcooked if it is grey.
While pork can be safely cooked at 130F (54.4C), many people find the slightly pink color of pork cooked at this temperature to be unsettling. To compensate for cooking to medium (instead of mediumrare), I highly recommend brining the pork chops to break down some of the support structure of the muscle fibers and to increase the water holding capacity of the meat; the maximum water uptake occurs when brining in a 7–10% salt solution, with the chop absorbing 20–25% of its weight (Graiver et al., 2006).
Brine in a 7% salt, 3% sugar water solution (70 grams salt and 30 grams sugar per 1 liter) in the refrigerator for one to two hour. (If tenderizing with a Jaccard, do so before brining.)
Rinse, dry with paper towels and season with Kosher/ sea salt and coarse ground pepper. Vacuum seal pork chops (one per bag).
To cook, place in a 141F (61C) water bath for the cooking times in the Table 5.1. [The chop may be rapidly cooled in ice water (see Table 1.1) and frozen or refrigerated at below 38F (3.3C) for up to three to four weeks until needed.]
Remove chop from vacuum bag, pat dry with a paper towel, then sear quickly with a blowtorch or in a pan with smoking vegetable or nut oil.
#Fake Smart
hank scorpio is offline   Reply With Quote
Old 02-01-2018, 06:56 PM   #49
The Yancey's Avatar
2009 Awards: Awards for best Posters - Given for: Best Signature
CockyCash: 4751350
The Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot materialThe Yancey is USC mascot material
Typically you can let your food stay in the spa for 4+ hours after the set time with no ill effects. It will never cook past the temp you have set. Much longer than 4 hours and it can get too tender though, almost mushy.
Order Of The Spur
I miss Old Cocky Talk
The Yancey is offline   Reply With Quote
Old 02-01-2018, 08:58 PM   #50
CockyCash: 10500
Definitely gonna grab one of these
Old 02-02-2018, 11:03 AM   #51
Heisman Winner
thekob's Avatar
CockyCash: 100700
While pork can be safely cooked at 130F (54.4C), many people find the slightly pink color of pork cooked at this temperature to be unsettling. To compensate for cooking to medium (instead of mediumrare), I highly recommend brining the pork chops to break down some of the support structure of the muscle fibers and to increase the water holding capacity of the meat; the maximum water uptake occurs when brining in a 710% salt solution, with the chop absorbing 2025% of its weight (Graiver et al., 2006).
Yep, that's the obvious benefit. also, still pink on the inside is how tenderloin should be cooked imo. It's not that big of a risk (there's a difference between pink and raw) and if you cook it to the temp that the gov't suggests, it'll be a lot tougher.
Related to this, if you're making something with raw eggs and you're worried about it, you can pasturize the eggs with the sous vide as well.
Thanks for the recipe, I figure we'll probably be doing this sometime this week.
GOD
USA
SEC
Old 02-02-2018, 11:30 AM   #52
sandstorm2001
CockyCash: 50700
like cookie dough for example, just be sure to pasteurize your flour as well, which can be done in the oven. Don't try to bake it after pasteurizing eggs and flour. I can't remember off the top of my head if the eggs get messed up, but the gluten in the flour breaks down when you pasteurize it, so the cookies wouldn't turn out right.
Old 02-02-2018, 11:31 AM   #53
uscfsu23
uscfsu23's Avatar
Yeah I have explained it to her but she can be a bit hard headed... shocking I know. Do you guys have a good site for cooking times by weight? Obviously a 5lb Tenderloin time will be longer than a 1lb Tenderloin.
I am still a bit new to Sous Vide, but man it is awesome!
Old 02-05-2018, 10:15 AM   #54
Heisman Winner
thekob's Avatar
CockyCash: 100700
My assumption is that it's more about how thick it is rather than weight, since it's all about how long it takes to heat to the inside for the correct amount of time.
I'll let you know if I find a general table though, since I want to find one as well.
GOD
USA
SEC
Old 02-05-2018, 10:18 AM   #55
Heisman Winner
thekob's Avatar
CockyCash: 100700
I've never even heard of pasteurizing flour.
I googled and found this:
http://www.marlerblog.com/legal-case...-heat-treated/
It looks like it's mainly because it's never been heat treated, so to be safe it should be....not that it's really dangerous like many figure raw eggs are.
Also, I love this quote:
"The investigators found that consumption of cookie dough appeared to be a popular practice, especially among adolescent females."
GOD
USA
SEC
