2k15
CockyLifer
FurmanCock
SC Gamecock
Cockypantherfan
Senior Rooster
Blackland
Garnet&BlackOp
THIS IS WHAT WE DO. (799)
Johnathan Gipson (476)
We're going have our (393)
Radio Station in Gre (258)
Old Dominion upsets (237)
AAC (170)
Lamb on the grill (142)
CockyGaming’s way to (106)
We're going have our hand
Old Dominion upsets Virgi
Week 4: Around College Fo
THIS IS WHAT WE DO.
Bowl eligible?
CockyGaming’s way to earl
**USC (1-1) vs. Vanderbil
Sure, it's a long shot
What happened to UNC foot
Will the Gamecocks Score
Old 01-25-2018, 11:16 AM   #1
Heisman Winner
thekob's Avatar
CockyCash: 100700
thekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot materialthekob is USC mascot material
Default Home Wifi Systems
Has anyone used one of these? Is it essentially a router with a couple repeaters, with the main difference being that it's easier to set up?
Here's what I'm referring to:
https://www.amazon.com/eero-Pro-WiFi...=eero+wifi+pro
We've got a large house and multiple users, so this is something we're considering.
Also, we've got Ethernet cables (I believe) set up to go throughout the house. I'm wondering if I can hook up the router installed by Windstream to that and plug in any devices possible, and also plug in additional routers (rather than range extenders) to broadcast on an identically named network. Would doing that (essentially two routers that are set to the same network name) make things better or worse?
Just FYI, I very well may have gotten some of the terminology wrong, so please bear with me.
GOD
USA
SEC
thekob is offline   Reply With Quote
Old 01-25-2018, 11:28 AM   #2
JohnnyB21
JohnnyB21's Avatar
CockyCash: 20000
JohnnyB21 is USC mascot materialJohnnyB21 is USC mascot materialJohnnyB21 is USC mascot materialJohnnyB21 is USC mascot materialJohnnyB21 is USC mascot materialJohnnyB21 is USC mascot materialJohnnyB21 is USC mascot materialJohnnyB21 is USC mascot materialJohnnyB21 is USC mascot materialJohnnyB21 is USC mascot materialJohnnyB21 is USC mascot material
Default Re: Home Wifi Systems
If you're gonna fork out the money for that, just get digital life from AT&T. Cheaper up front and great quality
Vandy we comin'!
JohnnyB21 is offline   Reply With Quote
Old 01-25-2018, 11:38 AM   #3
Been caught moddin'
Spur's Addiction's Avatar
CockyCash: 1201856
Spur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot materialSpur's Addiction is USC mascot material
Don’t know anything about these specifically. But cable will always be faster and more reliable then WiFi. So if you have it already installed use it.
If you have more the. One router, only one is your actual router. Put any others in pass through mode.
Spur's Addiction is offline   Reply With Quote
Old 01-25-2018, 01:39 PM   #4
ShutTheSuccop
Go Cocks!
ShutTheSuccop's Avatar
CockyCash: 101600600
ShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot materialShutTheSuccop is USC mascot material
how is that different than using extenders? I mean we have extenders in our house and they work great! I know nothing about these things and our home is not that big but I can't imagine dropping that much coin when there are already cables run throughout your house
ShutTheSuccop is offline   Reply With Quote
Old 01-25-2018, 01:43 PM   #5
FlorenceCock
FlorenceCock's Avatar
CockyCash: 1220000
FlorenceCock is USC mascot materialFlorenceCock is USC mascot materialFlorenceCock is USC mascot materialFlorenceCock is USC mascot materialFlorenceCock is USC mascot materialFlorenceCock is USC mascot materialFlorenceCock is USC mascot materialFlorenceCock is USC mascot materialFlorenceCock is USC mascot materialFlorenceCock is USC mascot materialFlorenceCock is USC mascot material
It you have cat5e run throughout your house it is a million times better to hook up your devices hardwired than it is to use them wireless. If you still find yourself needing wifi in parts of the house that your main router will not reach then buy some wireless access points and plug them into the Ethernet ports in those rooms to extend your coverage. It would be WAY cheaper than buying the system you are looking at and work much better. Also the system you are looking at is way overpriced. If I were to do a mesh system like that I would go wtih the Netgear Orbi system. It is cheaper and better supported. https://www.amazon.com/NETGEAR-Orbi-.../dp/B01K4CZOBS
FlorenceCock is offline   Reply With Quote
Old 01-25-2018, 02:21 PM   #6
GoldenSpur7
obscurum per obscurius
GoldenSpur7's Avatar
CockyCash: 4951
GoldenSpur7 is USC mascot materialGoldenSpur7 is USC mascot materialGoldenSpur7 is USC mascot materialGoldenSpur7 is USC mascot materialGoldenSpur7 is USC mascot materialGoldenSpur7 is USC mascot materialGoldenSpur7 is USC mascot materialGoldenSpur7 is USC mascot materialGoldenSpur7 is USC mascot materialGoldenSpur7 is USC mascot materialGoldenSpur7 is USC mascot material
Man, 500 clams? I would just try a stronger (wifi) router first.
GoldenSpur7 is offline   Reply With Quote
Old 01-25-2018, 06:55 PM   #7
Flameout12's Avatar
Flameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot materialFlameout12 is USC mascot material
Especially if most of the devices are mobile (phones/laptops/pads).
I guess you could hard wire a smart TV if needed. I run mine via wifi.
Flameout12 is offline   Reply With Quote
Old 01-25-2018, 07:52 PM   #8
Jwilson
60 Year Fan
Jwilson's Avatar
Jwilson is USC mascot materialJwilson is USC mascot materialJwilson is USC mascot materialJwilson is USC mascot materialJwilson is USC mascot materialJwilson is USC mascot materialJwilson is USC mascot materialJwilson is USC mascot materialJwilson is USC mascot materialJwilson is USC mascot materialJwilson is USC mascot material
You can't use multiple routers if each one is in full router mode. Part of a routers function is to communicate withe the ISP network to handle routing, DNA requests, DHCP functions etc. More than one router doing this won't work, normally. It can be done, but it requires a lot of IT expertise.
A wireless router is actually a router and a wireless access point in the same box. The access point function simply replaces the hard wire connection. Wireless Routers in pass thru mode simply have the routing function turned off and become access points. Individual Access points are hard wired to a router. You generally can't not have multiple access points advertising the same wireless network name.
It can be done, again with a lot of expertise. Think of a range extender as an access point that connects to the router wireless instead of hardwired. It also differs from an access point in that you can have more than one. It's sort of like an access point in pass thru mode.
In otherwords,just about anything can be done, provided the settings are available in the devices to design the networking functions. Meaning, if you go buy a couple wireless routers, plug them up and expect it to work, good luck.
I never use the ISP Equipments routing or wireless functions. A really good AC capable wireless router with 4 or more large antennas, coupled with one or more range extenders should do it. A lot of it also depends on how many devices you may have simultaneously streaming wireless.
FWIW, when i built my house, i had cat6 wiring put in in a bunch of places. Al. My computers and the main smart tv's are hardwired. This allows me to use less expensive routers, etc. I have a 3000 sq ft house (17 down, 13 up) and I use one wireless router downstairs and one repeater upstairs. My router is an AC 1900 class.
Don't get fooled by routers advertising high power. Wireless is a 2way conversation. A high power router shouts loud and your device may be able to hear it. But, unless it is also a high gain router (if it is, it will say so), it won't be able to hear your device. This is a main reason that range extenders are used. It puts the receiving antenna closer to your device.
I'm doing this on my phone. Please forgive the typos.
Jwilson is offline   Reply With Quote
Old 01-25-2018, 08:43 PM   #9
USC97
USC97's Avatar
CockyCash: 2000
USC97 has earned his spursUSC97 has earned his spursUSC97 has earned his spursUSC97 has earned his spursUSC97 has earned his spursUSC97 has earned his spurs
Love my google Wifi
USC97 is offline   Reply With Quote
Old 01-25-2018, 09:17 PM   #10
Make Yourself
uscfan1's Avatar
CockyCash: 5200
uscfan1 is USC mascot materialuscfan1 is USC mascot materialuscfan1 is USC mascot materialuscfan1 is USC mascot materialuscfan1 is USC mascot materialuscfan1 is USC mascot materialuscfan1 is USC mascot materialuscfan1 is USC mascot materialuscfan1 is USC mascot materialuscfan1 is USC mascot materialuscfan1 is USC mascot material
Digital life is the security and automation system att offers, bud.
uscfan1 is offline   Reply With Quote
Old 01-26-2018, 03:26 AM   #11
cocky0
cocky0's Avatar
2009 Awards: Awards for best Posters - Given for: Best Signature 2008 Cockytalk Award: 2008 Cockytalk Award - Given for: 2008 Fark of the Year Christmas Farking Contest: Christmas Farking Contest - Given for: Winning Farking Contest
CockyCash: 10100000
cocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot materialcocky0 is USC mascot material
Send a message via Yahoo to cocky0
This x1000.
However another, possibly cheaper option if you don't mind doing some configuration yourself is to just grab another router or two and put them into bridged mode. I've done this with old routers I have around the house when I need a little extra coverage in the back yard.
cocky0 is offline   Reply With Quote
Old 01-26-2018, 06:18 AM   #12
USC97
USC97's Avatar
CockyCash: 2000
My google Wifi is hard wired since I have cat5 throughout the house. Got 3 units for $250 during Black Friday. Simple set up, so I never needed any support. Their app allows me to shut down any device instantly. Did a lot of research and felt it was better than the competition due to its ease of use.
Old 01-30-2018, 06:07 PM   #13
Cockadoo
Cockadoo's Avatar
Cockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot materialCockadoo is USC mascot material
How is WiFi hardwired?
Cockadoo is offline   Reply With Quote
Old 01-30-2018, 08:19 PM   #14
USC97
USC97's Avatar
CockyCash: 2000
It is a mesh network. Only one unit needs to be connected via Cat5. The others can connect to the main via WiFi and then send their own signal. You can connect the additional units via cat5 if your home is wired. It creates a stronger signal.
Old 01-30-2018, 08:32 PM   #15
rioninusc
rioninusc's Avatar
CockyCash: 1000000056
rioninusc is USC mascot materialrioninusc is USC mascot materialrioninusc is USC mascot materialrioninusc is USC mascot materialrioninusc is USC mascot materialrioninusc is USC mascot materialrioninusc is USC mascot materialrioninusc is USC mascot materialrioninusc is USC mascot materialrioninusc is USC mascot materialrioninusc is USC mascot material
Here is a list of some that are cheaper.
https://www.pcmag.com/roundup/350795...etwork-systems
This is a nice system, it keeps the same network throughout the whole house, and you're connection doesn't get cut like with a plugin unit. I would only recommend this if you have demanding devices at each corner of the house.
rioninusc is offline   Reply With Quote
Old 01-30-2018, 11:13 PM   #16
JohnnyB21
JohnnyB21's Avatar
CockyCash: 20000
Edit. Nvm
Vandy we comin'!
Old 01-30-2018, 11:42 PM   #17
JohnnyB21
JohnnyB21's Avatar
CockyCash: 20000
I uhh... I don't even have an excuse. I misread everything known to man in his post. I'm even a manager for at&t. Smh...
Vandy we comin'!
Copyright ©2000 - 2018, vBulletin Solutions Inc.
